AC/DC estimator - where does it come from ?
In my program, I'm using AC & DC estimator block, in order to indicate RMS value of the signal. However, looking under his VI, I found interesting code for RMS value estimate, but I don't know, where does it come from ? Is there any general formula to be found somewhere in literature for such estimator ?
Message 1 of 10
(4,541 Views)
Is this a function of LabView or OpenG?  I can't find anythig called RMS estimator.  This may be your term.  Can you post a VI?
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 2 of 10
(4,539 Views)
it requires the advanced analisys package (Not in base) but its on the signal operation palatte
Message 3 of 10
(4,536 Views)
Thanks Jeff.
The information is buried in a Call Library function, which I can't access.  Perhaps someone a bit more inquisitive can answer this.  But no, no formula, at least on the surface.  It's probably buried in the .dll that's being called.
Message 4 of 10
(4,532 Views)
Do you need more than what is in the help?
AC & DC Estimator Details
You often need to measure the AC and DC content of signals you digitize. This VI applies the Hanning window, which is sufficient for separating most of the AC energy from the DC bin. If you have a periodic signal and you do not have an integral number of periods in the acquisition, spectral spreading occurs regardless of whether you perform an FFT later. The coherent gain and equivalent noise bandwidth constants for the Hanning window that this VI uses compensate for windowing effects on the gain and bandwidth.
LabVIEW uses the efficient mean and variance computations instead of Fourier analysis to determine the total AC energy and the true DC level.
Message 5 of 10
(4,521 Views)
For those, who can't find this VI, I attacked below the "body" of this function. The desription in the help is ok, however I need to know, where the coherent gain (cg) and equivalent noise bandwidth (enbw) constants comes from, i.e. 0.5 and 1.5. Can I find this values and formulas somewhere ? or is it well known that such values are connected with properties of Hanning window ?
Message 6 of 10
(4,505 Views)
Ok, I've found an answer to my question in first post. Topic can be closed.
Message 7 of 10
(4,477 Views)
What did you find?  Care to share?
GCentral
Message 8 of 10
(4,470 Views)
Also, please mark the solution for you problem so others may be helped in the future.  Thanks.
Message 9 of 10
(4,453 Views)
http://www.bores.com/courses/advanced/windows/files/windows.pdf
http://zone.ni.com/reference/en-XX/help/371361E-01/lvanlsconcepts/dc_rms_error_sources/
http://www.noise.physx.u-szeged.hu/DigitalMeasurements/AcquisitionAndProcessing/PowerSpectrum.pdf , pages 20-21.
In this documents, I've found information about coherent gain and equivalent noise bandwidth of particular window. Additionally, in the last document, there is described relation between variance, standard deviation and rms value of AC signal. The only problem is such, that I haven't found any exact formula connecting window and variance of the signal. Binding this information altogether, it only can be assumed that square-root of variance divided by coherent gain squared times equivalent noise bandwidth gives estimator of rms value of AC signal.
Message 10 of 10
(4,447 Views)
