AC Voltage Ramp
Hello Community,
I am doing a project in which I need to create an AC voltage ramp as the one showed here. I am quite new to LabView so I do not know how to proceed. It would be much appreciated if you help with this issue.
I want to change the output from 0 to 5 V in 1 second. The frequency remains unchanged. Any suggestions ?
(2,789 Views)
It totally depends on what equipment you are using.
In our lab we have several programmable AC power sources. Most of them have a transient sequencer where you can program a start voltage, end voltage, and step or ramp rate.
Program then initiate the sequence and the power source does all the work.
=== Engineer Ambiguously ===
(2,786 Views)
Accepted by topic author Danny0806
If you're using an AWG, this is how I would generate the signal.
VI (14.0) attached
Santhosh
Soliton Technologies
(2,772 Views)
Santo_13 you’ve saved a life my friend. Thanks a lot
(2,708 Views)
Thanks a lot for your info. So much appreciated
(2,707 Views)
