AD5232
Has anyone developed any code to control Analog Devices AD5232 Digital Potentiometer through a USB port? Any help or direction would be greatly appreciated.
Message 1 of 8
(3,828 Views)
I don't know of such code, but do you know if the instrument is in the USBTMC class? If so you can use VISA to communicate with it in a message-based manner. Also, you may want to contact the manufacturer to see if they have any code they can give you from their development/testing internally!
Repost if you have further questions!
Thank you,
JLS
Best,
JLS
Sixclear
Message 2 of 8
(3,810 Views)
Hi Bullet,
........have used Analog Devices Digital Pot's and controlled via LPT.
Find attached a small vi for AD5207. You will get an impression, how
to communicate with such a device .......... change it for your needs.
Hope this helps ......
Regards
Werner
Message 3 of 8
(3,801 Views)
Werner,
I tried to ping you a few days ago. You seem to have a lot of experience in this area. I have the 5207 stuff from a previous posting. Is there a private messaging option here?
Message 4 of 8
(3,796 Views)
Was the previous post and attachment helpful? Repost if you are still having trouble!
Best Regards,
JLS
Best,
JLS
Sixclear
Message 5 of 8
(3,776 Views)
we are already in contact via private email... - thank you for your support.
Werner
P.S. By accident I looked to this forum and saw this posting - was very
seldom here in last weeks..........
Message 6 of 8
(3,768 Views)
No problem, thanks for the update!
Best Regards,
JLS
Best,
JLS
Sixclear
Message 7 of 8
(3,749 Views)
The code posted was modified to accommodate a 24 bit word clocked in on the parallel port. Thanks for all the responses.
Chris
Message 8 of 8
(3,740 Views)
