AD5541/5542 Digital-to-Analog converters from Analog DEvices
Dear Friends,
Does anybody have experience programming in Labview the AD5541 or AD5542 boards (Digital-to-Analog converters) from Analog Devices (http://www.analog.com/en/prod/0%2C2877%2CAD5541%2C00.html)?
LabView code examples or description of the general approach to this task would be much appreciated!
Thanks in advance
(2,960 Views)
Update:
My PXI system has NI-6534 board which I can use for digital output. But I need to perform Digital-to-Analog conversion by the remote AD5541 board.
Is there a way to do this?
(2,956 Views)
ampm <x@no.email> wrote in news:1167847809091-459531@exchange.ni.com:
> Update: My PXI system has NI-6534 board which I can use
> by the remote AD5541 board.Is there a way to do this?
That's a chip, not a board. Get the data sheet, look at the logic
diagrams, and you should be able to bit-bang the three logic inputs (well,
two plus a chip select) with your 6534.
Alternatively, the chip uses SPI communication. You can probably find some
help by searching for SPI on the NI site. It also looks like a third party
has a $200 solution the will let you do this via a parallel port, complete
with labview drivers, at http://www.calbay.com/product16.html
Scott
Reverse name to reply
(2,940 Views)
