AD9854 Labview FPGA control
I am trying to write a Labview program to control two AD9854's which will generate the signal for AODs in an optical trapping setup. Unfortunately I don't have much experience with Labview so I was wondering if someone already had the VI's to do this with Labview FPGA. We have a PXI-7854R installed in a PXIe-1062 Chassis. The 7854R is connected to a SCB-68A breakout box which is then connected to the AD9854 via ribbon cable. the AD9854 has a 14-pin DIP, 49.152 MHz fixed output, HCMOS logic, temperature compensated crystal oscillator (TCXO) installed (we are just using one board for now to test bench). I have been working off of the VI's supplied by the Comstock Lab which are available here: https://www.pa.msu.edu/people/comstock/software.html  but we only need the AD9854 control portion, not the whole Fleezers control. I have attached the project I have been working on, currently not working, I think its a timing issue. any help would be much appreciated. I can add more info if needed. Thanks.
(3,899 Views)
Hope someone will have code to help you directly but in the meantime:
1. Start with the examples that come with LabVIEW for the 7854R; they should be your baseline for ensuring you have hardware working.
2. As a good guide for LabVIEW FPGA, review to: https://www.ni.com/en/support/documentation/supplemental/13/the-ni-labview-high-performance-fpga-dev...
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(3,878 Views)
Got it working! just needed some help from someone with some programming experience to help debug.
(3,844 Views)
