ADAM 4050
Hi everyone,
Please help me.I am trying to communicate with ADAM 4050 with VISA files.
Advantech has there own software from which you can send Commands and check card's reply. I have attached screenshot of one command.
I tried to send same command from Labview, but it is not working. I am also attaching Labview code.
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(5,146 Views)
What exactly isn't working? Any error messages? Give more details. Also you have not closed the reference in your LabVIEW program. Try that out. Post with more details.
Trying to help.
Mathan
(5,137 Views)
Gak,
Are you setting the com port number correctly
Is hyperterminal working?
Have you installed the drivers?
(5,130 Views)
I have connected it to COM1 only. Please see the error.I have also attached command table.
And yes hyperterminal is working.
Message Edited by gak on 11-30-2009 09:43 PM
Gaurav k
CLD Certified !!!!!
(5,111 Views)
See the attached image and can you tell me What character is it (Circled in red) ?
Gaurav k
CLD Certified !!!!!
(5,098 Views)
Accepted by topic author Gak
Hi guys,
I got the answer. Please see the attached image.
Anyways...Thank you.
Gaurav k
CLD Certified !!!!!
(5,094 Views)
