ADC/DAC, flexrio, NI-5782
Hi.....
I want to send some data from DAC and want to receive the same from the ADC. I am using Flexrio + NI-5782 Adapter Module.
I am not able to understand the concept of generating four 16 bit integer samples by the DAC and generation of two 16 bit samples by the ADC and hence I dont know how to transmit and receive my data through the ports of the CLIP namely N,N-1,N-2,N-3......;
It would be helpful if someone could provide me a simple example so that I can tranmit an integer and receive the same .
Regards
Message 1 of 1
(3,039 Views)
