ADI Blackfin 2.5, LabView 8.5 on VISTA problems
I have lot of problems running LabView 8.5 on ADI ADSP-BF537 EZLITE embedded module on VISTA SP1.
Below are some examples as *.jpg.
Continuing about 3 to 5 times until I can finaly "Build" the application. The same with Linker and Loader.
I tried lot af adjustement, running LabView as Administrator and so far.
I have spent about 3 days on this project.
Does anybody have the same experience or some hints to improve the problem?
Peter Horn
(2,676 Views)
I had nearly the same problems, whe I started with LabVIEW Embedded a year ago. In my case, a lot of problems came up because of the installation order. First LabVIEW, then VisualDSP++ and then LabVIEW Embedded. Then I had a couple of wrong settings in my project regarding the right EZ-Kit. (Silicon Revision, ...). From your post it seems to be anywhere behind those installation and configuration steps, because you say it takes 3 to 5 times, but then the build process works fine. Am I right? If this is true, I need some research from your site? Can you reproduce this with a simple VI (Small Calculation), have you got some further informations about you VI or is it possible to post the source code! With this informations I can ask some developers, what might be wrong here.
Best regards
Alex Rudolph
NI Switzerland
(2,621 Views)
Hi Alex
I gived it up to use LabView with Blackfin on my Vista notebook.
I even did not expected somebody to look at my problem.
I am now working with my XP notebook and I found it more and more exciting and fantastic as developement tool. Congratulations!
I do not have this problems with XP. However, I have tried it again and send you my test project3 with VistaError picture just to prove that I am not kidding.
On XP it runs without problems.
Regards Petr Horn
Mobile phone in Switzerland: 0041 (0) 78 788 98 20
(2,615 Views)
