ADO Error: 0x800A0E7A
I am trying to read from an access database.  I am using 32 bit LV2020.  I do not have the 64 bit database connectivity toolkit installed.  I did, but I uninstalled it.  When I try to query the database I get the following error message
NI_Database_API.lvlib:DB Tools Open Connec (String).vi->Connect to Access DB.vi->Connect to Kidde DB.vi->Connect, Query and Fetch 1D String Data.vi<ERR>ADO Error: 0x800A0E7A
Exception occured in ADODB.Connection: Provider cannot be found. It may not be properly installed.
Visit ni.com/info and enter the Info Code LVDCT_64bit_Provider for more information about why the provider cannot be found.
My searches in the forum have not turned up any results that seem relevant.
Message 1 of 1
(1,017 Views)
