ADS1256 LINX SPI
Hello everyone
I installed LINX firmware on the Arduino Uno board to use Labview software. I want to use the ADS1256 24-bit ADC card to measure sensitive signals (biomedical, EMG, ECG, EEG). This card uses the SPI protocol. I connected the pins of the board to the Arduino board correctly. I ran this board with Arduino code without any problems. But LabVIEW seemed more convenient to me in terms of visuality and ease of use. I showed the block diagram in the pictures below. I read meaningless values on the Labview front panel. I don't understand the write data part. Analogue input type (single-ended or diff mode) and input channel selection. I do not understand the selection of PGA ratio and data rate (SPS). As far as I understand, the selection of these parameters is done via write data. I need your urgent help on this subject. I have attached the VI file.
https://www.ti.com/lit/ds/symlink/ads1256.pdf?ts=1701098374408&ref_url=https%253A%252F%252Fwww.ti.co...
Arduino Board        ADS1256 Board
Pin 9                        DRDY
Pin10                       CS
Pin11                       DIN
Pin12                       DOUT
Pin13                       SCLK
5V                            5V
GND                        GND
Message 1 of 1
(1,672 Views)
