ADT7310 SPI communication in LV
Hi
Has anyone has a VI for reading temp from the ADT7310 temp sensor. I am not very familliar with SPI com
http://www.analog.com/static/imported-files/data_sheets/ADT7310.pdf
(2,515 Views)
Hi there,
Here is an article on the SPI protocol and how it can be acheived in LabVIEW.
http://www.ni.com/white-paper/9119/en/#toc3
The manual you have linked seems to cover how communication with the device including reading and writing data.
I was not able to find any drivers for you device on our instrument driver network - possibly you could try requesting one.
http://www.ni.com/devzone/idnet/idnet.htm
There are however drivers for other Analog Devices hardware.
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/ssnav:ipn/q/analog%20devices...
I hope this helps
Tim, CLD, CTD
National Instruments (UK & Ireland)
________________________________________________
"No problem is insoluble in all conceivable circumstances"
(2,480 Views)
