AES 128(ECB) library for Labview
Hello
I wish to encrypt with AES 128 the communication using ECB(Electronic Codebool) mode.I came across this link while looking in the forum "https://decibel.ni.com/content/blogs/viGods/2012/06/04/labview-advanced-encryption-standart-aes-libr... it seems to be doing encryption/decryption using the CBC mode.
Is there any Labview library for AES encryption(ECB mode) available?
Bodhi.
(7,009 Views)
The link isn't working...
(6,009 Views)
You could try this instead: https://lavag.org/topic/14889-cr-encryption/#comment-89309
This is the original. The link in the first post was a blatant copy rip of this code published to be his work! Apparently NI has removed it and rightly so.
Rolf Kalbermatter  My Blog
(6,001 Views)
