AES 128 and USB communication
I wish to encrypt with AES 128 the communication between my .vi and USB port, it's
possible? I am able to modify firmware on USB hardware.
Do you have any suggestion for methods/softwares/labview patch/etc?
Thank you
Livio Pizzuti
(3,633 Views)
Hi Livio,
there isn't a direct implementation of AES encryt code in LabVIEW; but you have two choices:
- Using the library Crypto-G for LabVIEW made by VARTOR ( http://www.vartortech.com/cryptog.html );
-Using a  dll or control ActiveX made by different companies with the  Call Library Function Nodes and ActiveX or .NET invoke nodes.
Simo
(3,596 Views)
Ok, thank you for the info!
If I have a source code (in ex. xxxx.c) can you write me the passes how can I use this code (how can I call it, how can I compile it, etc).
(3,575 Views)
