AES128-ECB PKCS5 Padding
I want to find a VI of encryption algorithm AES128-ECB with PKCS5 padding, which is a common encryption algorithm. I have found a LLB file——Crypto.llb and there is a AES128 in it, but it isn't AES128-ECB. And I can never find another VI to solve my problem. Can you give me some help?
(3,407 Views)
Have you seen the NI community forum post in link below?
 https://forums.ni.com/t5/LabVIEW/AES-128-ECB-library-for-Labview/td-p/2839264?profile.language=en
Best regards.
(3,352 Views)
Thank you, hovo. I've downloaded the VI attached in the post, But it doesn't work.
(3,333 Views)
I am afraid that there is no ready solution.
(3,317 Views)
Yes. But I will use the CLN node to pack a DLL file, which is edited by C and includes the AES128-ECB function. Hope it works.
Regards
(3,310 Views)
