AGPNA Create Display Trace.vi
Hi Everyone,
I'm using the NI driver for an Agilent E8357A series PNA located at http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=E3B19B3E9555659CE034080020E748...
When I attempt to creat a new trace and display it in the PNA display, I start by creating a new trace with the "AGPNA Configure Measurement Parameter.vi". In the help for this file it states that it doesn't also display the paramter and I should use the "AGPNA Create Display Trace.vi". Unfortunately this file does not exist.
Has anyone created their own version of this file, or has some experience with this driver that can point me straight? Thanks.
Message Edited by jaysmall on 09-21-2009 10:32 AM
(2,956 Views)
I've taken a look at this and I believe what you are looking for is the Configure Display Trace.vi. If you place that on your block diagram, it has an input for Mode. By setting this input, you can create a display trace. Hope that helps!
-Zach
(2,935 Views)
