AI Control gives error: 10452 occurred at AI control. Possible reasons: NI-DAQ LV no interrupt level is available for use.
How can I run out of interrupts while accessing my DAQPad? Does
the community have troubleshooting suggestions?
(2,872 Views)
You don't say which DAQpad. If this is a device on your parallel port then
you will need to make sure that the parallel port has an interrupt assigned
and not just a base address.
Check out the following from the NI Knowledgebase:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/bf7960eb90
ef882a8625654e007d8b1a?OpenDocument
Ian
"Riverside Consulting, LLC" wrote in message
news:506500000008000000643E0000-1012609683000@exchange.ni.com...
(2,872 Views)
