AI Group Config
I'm trying to find an example for using AI groups, but haven't been
successful. Using a PCI-6071E (E-series) DAQ Card, I want to start two
analog input collections - one running at 100Hz using some of the
channels, and the other with the remaining channels at 1000Hz. On
starting the second acquisition I get error -10609 at AI Control. I'm
doing:
AI Group config (group 0) -> AI Clock Config -> AI Control (to start)
-> LOOP (to collect data) -> stop
AI Group config (group 1) -> AI Clock Config -> AI Control (to start)
i.e. two separate threads. Any examples / tips?
To complicate matters, I'm going to use the second acquisition (1000Hz)
with DAQ Occurrences so that I can count transitions on a part
icular
analog input channel. I haven't got as far as this as the above error
happens before I get there.
Any help would be greatly appreciated.
Tim
(3,259 Views)
You can configure as many groups as you want, but you can only do one
transfer at a time.
There are two ways to do the 100Hz/1kHz scan simultaneously:
1. Scan all channels at 1kHz, separate the columns of the 2D waveforms into
1D arrays (one per channel).
Then use decimate on the column arrays that need to be scanned at 100Hz
to reduce their size.
2. Scan all channels at 1kHz, but put the 'fast channels into the scanlist
10 times as often as the slow channels.
The resulting data will be somewhat messy: you have to find the right
locations in the array for each sample.
search for 'multirate' at zone.ni.com. (Requires some direct NIDAQ
calls)
Counting transitions:
If your card contains Hardware analog triggering you can route the output of
your trigger
circuitry to an onboard counter that counts events.
all MIO-E-3 and E-1 cards can!
Tim Pragnell wrote in message
news:396CA0FA.FBE3CD97@physiol.ox.ac.uk...
> Hi,
> doing:
> with DAQ Occurrences so that I can count transitions on a particular
> Tim
(3,259 Views)
