AI Sample freq. and Samples / Chan
Using LV7.1 with Win_XP.
In a DAS code, using the Digital Edge Counter for firing a Timed Loop. ( Refer the enclosed diagram )
Intially I was acquiring only one channel and required a Timed loop with 50ms timing. Hence configured the Sampling Freq at 200Hz ( 5 ms period ) and took 10 Samples / Chan. I thus got exactly 5ms x 10 = 50ms.
Later I acquired 5 channels @ the same 200 Hz and 10 Samples / Ch. To my surprise I got the same 50ms Timed loop triggers. I don't think I am quite clear whats happening ? The number of channels that I acquire does not seem to alter the 50ms triggers.
Thanks for any clarifications on above.
Raghunathan
LabVIEW to Automate Hydraulic Test rigs.
(2,875 Views)
Accepted by topic author MogaRaghu
Pulled out this VI from the disk ( must have got it from the forums earlier ) and that had answers to all my doubts !!
Raghunathan
(2,827 Views)
