Hi
I'm running SCXI 1100 and 1126 modules in a SCXI 1001 rack, on a windows 2000 SP3 PC using a 6052E NI DAQ card, LV 6.1 and the latest NIDAQ.
I am trying to configure, in parallel, the AI aquisitions for the 1100 (AI) and the 1126 (frequency)modules, both at the same scan rate, but whenever the second AI Start is run I receive the Error -10609, Transfer in progress error. They each have a seperate group number at AI Config and the AI configs generate seperate Task ID's for them. I configure both, then try to start both.
Effectively I suppose I'm trying to start the card twice I imagine. AI start is the only problem, and can't currently see a way round it. The shipped examples run either one or the other, and work fine (naturally
enough).
Many thanks for any help.
