AI acquire waveform
For my project, I am using a last year student's VI as reference, but when loading it up, it asks for a "AI Acquire Waveform.VI" which I cannot be found, and there is no "data acquisition" tab under which it is normally found according to the manual, why is this?
(8,985 Views)
Hi AV34,
What versions of LabVIEW/DAQ do you have installed?
If you installed DAQmx 8.0 then the traditional drivers (NI-DAQ) would not have been installed.
You need to install DAQ 7.4.1 or earlier onto your computer to get the traditional DAQ vi's.
All that said and done.. What aquisition device are you using? (DAQmx might be the beter way to go)
Many Thanx
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
(8,977 Views)
Hi again AV34,
Just thought I would post back and see how you are getting on with youa application.
Any luck getting it to work yet?
Thanx
AdamB
(8,964 Views)
yes it works fine now, thanks.
(8,955 Views)
how i can find this in labview 8.0 proffesional cause i try to find it but i can't found it. and may be can someone to tell me  where to find
AO update channel.vi and  AO generate waveform.vi
tanx before
(8,690 Views)
This is a two year old thread but Adam's answer above is still valid. Read his response and then download the driver. You should also have traditional DAQ on your device drivers CD and you can simply install it from there.
(8,688 Views)
Link is not valid!
(6,553 Views)
