AIHARD.lsb not found error
I've got an application that uses AI for I/O.
Everything works fine, except periodically while
loading my VIs, I receive an error saying that
AIHARD.lsb could not be found. This problem
causes all AI library VIs not to working.
My current solution to the problem is to
reinstall LabVIEW which works, but is
cumbersome. Has anyone seen this happen before
and if so what is the solution to the problem?
I appreciate any help you can give.
Lukasz Pawlowski
Sent via Deja.com http://www.deja.com/
Before you buy.
(3,230 Views)
I have the same problem.The only sollution i have found is the same as yours,reinstall LabView.
I believe the next days i will find a better sollution.
(3,230 Views)
