AIM TTI 1908 DMM (IVI Driver) - Unstable Data Comms
Hi all,
I`ve just purchased an AIM TTI 1908 Bench Multi Meter, with the aim (pardon the pun) of taking some resistance measurements during a test sequence.
This device has a USB port, and AIM provide a Labview IVI driver. I`ve got the device setup in MAX and can retrieve a measurement successfully. But not reliably.
For those of you that use IVI drivers / instruments, do you have issues with requesting multiple readings in sequence ? I`m also getting errors if I reset the device between measurements, after about 3 readings it fails to reset and generates an error.
VI snippet attached, hopefully the code is ok
Nick
Message 1 of 1
(1,417 Views)
