AL5D
I am using AL5D arm to pick and place the objects. Its using SSc32 servo controller. Do anyone know how i can control the AL5D arm with LabVIEW?
How can I control multiple servos simultaniously with LabVIEW?
Dev
(2,897 Views)
Well, the datasheet for the servocontroller shows that it has a serial port - that is how you would connect it to LV. To control multiple boards, you will need multiple serial ports.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,870 Views)
