AMTI Biomechanics
G'Day All,
Has anyone come across (or more specifically, worked with) an AMTI Biometrics Force Platform? They are often used in athletic monitoring and training, and I was wondering if anyone had developed LabVIEW drivers or a appropriate application to acquire (and perhaps even process) their signals? I'm using a Data Translation DT3002 DAQ card...
cheers,
Christopher
Christopher G. Relf
Certified LabVIEW Developer
Christopher.Relf@mBox.com.au
International Voicemail & Fax: +61 2 8080 8132
Australian Voicemail & Fax: (02) 8080 8132
EULA
1) This is a private email, and although the views expressed within it may not be purely my own, unless specifically referenced I do not suggest they are necessarily associated with anyon
e else including, but not limited to, my employer(s).
2) This email has NOT been scanned for virii - attached file(s), if any, are provided as is. By copying, detaching and/or opening attached files, you agree to indemnify the sender of such responsibility.
3) Because e-mail can be altered electronically, the integrity of this communication cannot be guaranteed.
Copyright © 2004-2024 Christopher G. Relf. Some Rights Reserved. This posting is licensed under a Creative Commons Attribution 4.0 License.
(3,446 Views)
Chris,
Total Turnkey Solutions appear to supply VIs for acquiring data from Data Translation boards into LabVIEW. Check out this link:
LabVIEW VIs for DT3000
I don't have any experience with the Force Platform that you have mentioned, so I won't be able to help with analyzing the data returned from that device.
-Logan
(3,446 Views)
Thanks Logan - I've got the VI library on order!
cheers,
crelf
(3,446 Views)
