AMTI output
sorry Raven ,
that  is the image i wanted to send . when i am using the digital multimeter and measuring the voltage on the terminals fo SCB-68 it is different from what i acquired in labview
thanks
sweety
Message 11 of 14
(1,661 Views)
Hey sweety,
Is your signal source grounded (connected to a wall outlet or some other ground) or is it floating (a battery for example). Depending on your signal source, you will need to select a particular input configuration (RSE, NRSE, or Differential). I've attached a screenshot of a table that shows how to connect these configurations and when to use each one. I got this from the M-Series User Manual which can be found here on page 4-12. Could you check this and see which configuration best applies to your application?
Lars
Message 12 of 14
(1,649 Views)
Hi ,
i configured it as differential but still the voltage looks different on the terminal and labview? can u please explain why ?
thanks
Sweety
Message 13 of 14
(1,642 Views)
Accepted by topic author sa428
hi ,
after taking so much trouble the AMTI people say the output analog voltage of DSA is not great !!!
anyways  thanks to every one for trying to help me
Sweety
Message 14 of 14
(1,629 Views)
