AND operation on two signals
(2,849 Views)
You are going to have to give more details.  What are you inputs?  What do you expect out?  What have you tried already?  Why such a large image that is 90% white?
(2,847 Views)
Let me google that for you...
Boolean
Signals
(2,842 Views)
i am having three pulse signals 1kHz,2kHz and 100Hz.
during the positive cycle of 100Hz pulse, i need the 1kHz pulse to excite an LED.
during the negative cycle of 100Hz pulse, i  need the 2kHz pulse to excite another LED.
(2,813 Views)
Can you already read the signals? The LabVIEW code will look just like the image you posted if that is what you are asking.
LabVIEW 2012
(2,811 Views)
HI,
As previous posters have said, you can create exactly this setup in labview - it'll look just like your diagram. Use the Boolean primitives located in Functions>>Programming>>Boolean:
-CC
"If anyone needs me, I'll be in the Angry Dome!"
(2,779 Views)
