AO Group COnfig Error
I have created a sine and a square waveform according to the user requirements but when i write the two waves to the AO generate waveforms i get an error saying AO config error. I have also configured the input channels using AI config and other input SUb vi's. I dont knwo what to do.
(2,705 Views)
Vaidehi,
Are you using LabView 7.0 or newer (with DAQmx) or are you using an older version of LabView that only has the Traditional DAQ? Either way, there are several examples of analog waveform output included in LV. You can find them in the help menu under "Find Examples."
You coud get the AO config error for several different reasons. Its very hard to tell what it is without having the code. Are you doing simultaneous AI and AO? There is a shipping example for that also.
If you can't get this solved using the shipping examples please feel free to respond to this with your code attatched. It may give me some insight into whats going on.
-Sal
(2,705 Views)
