AO config AO write gives message error
Hello
When i open AO Config.vi, AO Write.vi and others in "DAQmx - Data Acquisition" apears the message "Error loading c:\...\Labview7.1\vi.lib\Daq\lvdaq.dll" "dinamic conection DLL failed"
I don't now why.
Do you no what is the problem.
Is there a solution?
(2,619 Views)
It looks like the DAQmx .dll has either been corrupted or deleted.
Easiest thing to try would be reinstall your DAQ drivers from either the CD or download the newest version from NI and try those.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,607 Views)
