AP2722(instrument driver) or AP2222(ActiveX to APWIN)
I recently asked a similar question but I want to try to re-ask a better question.
Is it well known that using Instrument Driver with 2722 will have easier implementation than LabVIEW with AP2222 via Active X?
I have the option to use either but I was just curious if the collective experience had an opinion about which one might be better to use.
thanks
Message 1 of 8
(4,351 Views)
Hi Danny,
You would be better off using the instrument drivers.  The 2722G and 2722A are NI certified, meaning that we've tested and verified it.  However, the 2722 is not NI certified, and may have bugs.  The instrument drivers can be found here:
http://search.ni.com/nisearch/app/main/p/bot/no/ap/tech/lang/en/pg/1/sn/catnav:id,ssnav:sup/q/2722/
The advantage of using the instrument drivers is that you have access to the code and functions.  If you do detect an error, you can troubleshoot it.  With ActiveX, you'll have to trust the publisher of the control that all of the functions work correctly.
Che T.
Message 2 of 8
(4,336 Views)
Thank you.
Message 3 of 8
(4,331 Views)
Hi
I am using ap2722 for my graduate project. I have to generate offset voltage from ap 2722 output. how can i generate offset voltage by using ap 2722's labview driver
Message 4 of 8
(4,242 Views)
Hi enes,
Which driver are you using to communicate to your device? Is it the 2722G, 2722A or 2722?
Allison M.
ni.com/support
Message 5 of 8
(4,226 Views)
i am using 2722 for project, driver name is "Audio Precision 2700 Series".
thanks,
Enes Karav,
Student of Electronics Engineering
Istanbul Technical University
Message 6 of 8
(4,221 Views)
Hi Enes,
As Che T. mentioned, the 2722 driver is not NI certified. I would recommend contacting the company who makes your device or else hopefully someone else on the forum will have used this device driver successfully to set offset voltage.
Allison M.
ni.com/support
Message 7 of 8
(4,201 Views)
Thank you;
Message 8 of 8
(4,193 Views)
