APPCrash on initialization of Labview
I get the following error notice when I try to initialize LabView.  It will not start correctly.
Problem signature:
  Problem Event Name: APPCRASH
Application Name: LabVIEW.exe
  Application Version: 10.0.1.4002
  Application Timestamp: 4d2fa7a6
  Fault Module Name: LabVIEW.exe
Fault Module Version: 10.0.1.4002
  Fault Module Timestamp: 4d2fa7a6
  Exception Code: c0000005
  Exception Offset: 018d7f76
  OS Version: 6.0.6002.2.2.0.768.3
  Locale ID: 1033
  Additional Information 1: dc0b
  Additional Information 2: 873d0176a93954fe135a8a4b75b24b24
  Additional Information 3: 4660
  Additional Information 4: 17053f6932b1708da7cd4ee5f404311c
Steven S. Hardy
(3,521 Views)
Is this the first time you've tried to run LabVIEW on this computer? OS version 6.0 indicates Vista. The exception code could be, I believe, related to a driver. What kind of computer do you have? What else besides LabVIEW have you installed? Have you tried a repair of LabVIEW? Have you tried an uninstall and reinstall? (Make sure to turn off your anti-virus during installation.) If you were installing drivers I'd suggest installing only the LabVIEW development environment to narrow it down.
(3,512 Views)
Is this the first time you've tried to run LabVIEW on this computer? YES
OS version 6.0 indicates Vista. The exception code could be, I believe, related to a driver. What kind of computer do you have? DELL XPS 1530 32 Bit.
What else besides LabVIEW have you installed? Not very much.
Have you tried a repair of LabVIEW? Yes, Twice.
Have you tried an uninstall and reinstall? NO (Make sure to turn off your anti-virus during installation.)
If you were installing drivers I'd suggest installing only the LabVIEW development environment to narrow it down. I just put in the disk and Run it.:  NI LabView for Lego Mindstorms.
Steven S. Hardy
(3,508 Views)
Dr. Hardy,
I think your best bet is to try reinstalling - did you try that yet? (make sure you uninstall your software through Programs and Features>NI Software)
(3,486 Views)
THANK YOU! That worked. Complete remove, reboot, reinstall and reboot again. then NI Worked.
Steven S. Hardy
(3,473 Views)
