ARDUINO MEGA 2560 Digital IO Control
 Hi, I can't connect L1 1D array to the digital I/O pin, I want to know which converter to use
(1,203 Views)
I don't have your toolkit, but what does it say in the context help if you hover over the input terminal?
Is there a reason you are still using the ancient LIFA instead of LINX?
(also note that you can simplify your comparisons by using an array diagram constant.)
(1,133 Views)
Hi Ancien,
What does your subVI expect as inputs?
(Why don't you use an autoindexing FOR loop to set your 4 DO channels?)
(1,107 Views)
Am using LiFA because I think it's better than LINX right?
I done it's projet, actually I want to use sensors ACS712 ans Zmpt101b to acquire current ant voltage!
I want to have the RMS values, I find an Arduino code but I want to translate it in LabView language!
I need help
The code :
Explique moi le code Arduino ci-dessous :
double sensorValue1 = 0;
double sensorValue2 = 0;
int crosscount = 0;
int climb_flag = 0;
int val[100];
int max_v = 0;
double VmaxD = 0;
double VeffD = 0; double Veff = 0;
void setup() {
Serial.begin(9600);
pinMode(A1, INPUT);
void loop()
{ for (int i=0; i<100; i++) {
sensorValue1 = analogRead(A1);
if (analogRead(A1) > 511) {
val[i] = sensorValue1; }
else { val[i] = 0; }
delay(1); }
max_v = 0;
for ( int i = 0; i < 100; i++ ) {
if ( val[i] > max_v ) {
max_v = val[i]; }
val[i] = 0; }
if (max_v != 0) {
VmaxD = max_v;
VeffD = VmaxD / sqrt(2);
Veff = (((VeffD - 420.76) / -90.24) * -210.2) + 210.2; }
else { Veff = 0; }
Serial.print("Voltage: "); Serial.println(Veff); VmaxD = 0; delay(100); }
(1,029 Views)
The function you are using allows you to write only one digital line at a time.
The input is a number not an array .
(1,021 Views)
