ARM build error
I have LM3S8962 evaluation board and labview embedded for ARM controllers. I used this for building applications and running on this evaluation board ( simple ones) Now recently i tried to run again, i am getting error " build failed with errors"  output of the error window is as follows:
Build target 'LabVIEW'
compiling RTX_Config.c...
..\System\RTX_Config.c(157): error:  #130: expected a "{"
compiling LM3S_EMAC.c...
D:\Program Files\National Instruments\LabVIEW 8.5\Targets\Keil\Embedded\RealView\Drivers\RL-ARM\Include\RLARM_Net_Config.h(31): error:  #256: invalid redeclaration of type name "S8" (declared at line 34 of "D:\Keil\ARM\RV31\INC\RTL.h")
compiling LVCGenIntInit.c...
compiling ARMproj2.c...
compiling lvEmbeddedMain.c...
Target not created
I dont understand what is this. Can some one help me out of this problem.
I  updated the uvision3 with recent updates that are available online from Keil.
These upadates have removed some configuration files?
waiting for the answer..
regards,
Nabhiraj, Kolkata
(3,346 Views)
the same error with vista and Mkd 3.40
Ελευθερία σημαίνει ότι μαθαίνεις να έχεις απαιτήσεις μόνο από τον εαυτό σου, όχι από τη ζωή ή τους άλλους
(3,279 Views)
