ARM porting guide precision
Hello
I'am presently trying to use a LPC2148 with LabVIEW 8.6. As specified in the ARM Porting Guide Ch. 2, I have check for the RTX_Config file and I found RTX_Conf_LPC21xx.c and Startup.s. So, I skiped the 4th chapter.
Then, I did Ché 5 and I didn't find a product with my uC board. So I did it. Then come back on Ch. 2. Tutorial talk about Retarget.c but I don't have this file for my uC. Same thing for the Ext_RAM.ini and Clock.ini files.
Do i just ignore these files or there a way to create it ?
Thank you.
(3,756 Views)
Hi Yan,
Just to clarify, your ARM target was not listed in the \Keil\ARM\RT Agent\RTX folder as indicated in chapter 5, so you went back to chapter 2 and found that you were missing the retarget.c, Ext_RAM.ini and Clock.ini files? What version of LabVIEW Embedded for ARM are you using with LabVIEW 8.6?
I am pretty sure that you will need these files, but I will need to do some research to find out how you can obtain them. I will look into this for you and get back to you as soon as I have updates.
Thanks!
(3,728 Views)
Yes, you're right. It was not listed in \Keil\ARM\RT_Agent\RTX folder as indicated in chapter 5 so I did the explanation of chapter 5. Then I came back in chapter 2 and I found that it was missing the retarget.c, Ext_RAM.ini and Clock.ini files.
I presently use LabVIEW 8.6 with the the LabVIEW Embedded module for ARM v. 1.1
thanks.
(3,712 Views)
