ARToolKit in LabVIEW
for my Master thesis, I am working on an augmented reality system to measure cucumbers from a camera image. I tried to work out the marker detection myself, but because it contains 3D rotations, I didn't succeed.
I came to the conclusion that it would be easier to implement existing c-code from the ARToolKit in LabVIEW. Does anyone have experience with this, or an idea how this can be done? Or does anyone have other experiences with augmented reality systems in LabVIEW?
Greetings, Hans
(4,613 Views)
I don't have any experience in augmented reality systems. I have enough problems with reality as it is. As far as using the ARToolKit, it seems that they provide a Visual Studio solution within the download. The solution is set up to generate libraries, but you should be able to use it to generate DLLs, which you can then call from LabVIEW. That's probably your best bet in using that toolkit.
EDIT: It looks like there's already some DLLs in the "bin" directory, though I'm not sure if those DLLs are the ones you need. You will need to look at the documentation for the toolkit to determine what functions you need to use.
Message Edited by smercurio_fc on 06-03-2008 04:33 PM
(4,585 Views)
hello
did u find anyway to solve your problem?
i want to do same action
if u have any experience, please help me
(3,848 Views)
Is there any  way to use ARTOOLKIT in labview
(3,746 Views)
