ASAM XiL
Does anyone know if it is possible to incorporate ASAM XiL (ASAM XIL) in LabVIEW? I have another program that can communicate over an ASAM XiL API and I need to connect that program with LabVIEW. (The other program is ECU-Test). I know this is possible with NI VeriStand (ASAM XIL API - Generic Simulator Interface - NI VeriStand Help - National Instruments) but we would like to use LabVIEW.
(3,678 Views)
Hurray! Another "Open Source" standard! Free of charge (for members)...
There's a C# reference library (for members)... That could help (for members).
If you have access to the specification, it would probably be not that hard to make it work.
Without the specification, who knows?
I'd run unless I got paid for a membership.
(3,659 Views)
Thanks for the reply! So you do not think there is a inbuild function palette or something in LabVIEW that supports the API?
Best regards
Christoffer
(3,649 Views)
Accepted by topic author ChristofferHjalmarsson
Definitely not build in.
I'm also pretty sure NI doesn't have an add-on for that.
There's ASAM XIL TestStand Steps Download - NI for TestStand... It might adapt to LabVIEW. If the steps are API calls (or VIs of course!) it might be easier than starting from 0.
On the tools network only ECU Measurement and Calibration Toolkit Download - NI mentions ASAM XiL.
(3,642 Views)
Thank you very much for the answer!
(3,614 Views)
I'm sorry it's not better news.
(3,602 Views)
