ASCII TO NUMBER
Hello every one...
  Iam suffering a lot about ASCII TO  number conversion...Actually i have a swr instruments it sending data through RS-232 protocol but the problem is iam receiving ASCII data but i would like to see as numeric.....plese help me
(4,830 Views)
Hi
Just typecast the ASCII value to a U8 numeric.
It's found in the "data manipulation" palette... You can use it to convert from one datatype to any other depending on the type input, so be careful to connect the correct type definition!
Hope this solves....
Kudos Welcome Smiley Wink
Santhosh Joel
Certified LabVIEW Developer
Best LabVIEW Programmer @NIDAYS 2015
(4,821 Views)
THANK YOU...Smiley Happy
(4,809 Views)
If your issue is solved you can mark it as the solution for your questions 🙂
Kudos 😄
(4,803 Views)
well, usually the rs232  data stream is coded in a hopefully known way 🙂
the vi to convert a string to byte array is found in the string conversion palette....  however usually the scan from string vi is a better way ...
If you run into problems post some sample data and explain the data format.
Greetings from Germany
Henrik
LV since v3.1
(4,776 Views)
@hanumeshbujji wrote:
Hello every one...
If you are using a string indicator, just right click on it and you can use the Hex view instead of the normal view.
(4,765 Views)
