ASCII to Int in arduino labview compiler
I appreciate that you have deleted your previous post, otherwise your childishness would come in front of others.
Instead of resolving the problem, if you give this kind of arguments on this platform, then sooner you will find few who will dare to ask questions here.
but anyways...
If you check my question properly, then i dint ask or blame that its a compiler issue or anything else. i just want to know the conversion method from ASCII to integer.
In labview there is type cast which can do the same but in Arduino ( TSXperts tool), there is no such provision available in home edition, it might have available in higher version which i have not used yet.
Thank you for co operation and time
Message 21 of 26
(1,297 Views)
but anyways...
If you think a threat or a scolding is going to make a difference with me, you had better think again.
It isn't NI software, so you need to ask TSXperts !
It's like asking Ford about a Toyota.
Message 22 of 26
(1,279 Views)
Why would i threatened to some one to whom i don,t know personally.
See there is nothing personal here, i came here to ask for help, But instead of helping, you just made fuss.
Let me remind you, your deleted post.
Do, you really think the replies you keep on giving me, are well professionally structured.
I think you took this task very seriously. I suggest those people to take rest and go for PICNIC ( Actual Vacation, not the terminology which you have used for my question).
Threat , scolding, You are openly using these words, and telling me to mind my word. I think for those there is best line Learn Before Teaching Others.
 I respect each and every person, on this forum, who are here to help, but not to make you realize.
Being an member of this forum, i request you to maintain the decorum of this forum, and if you have any problem with me, then you can message me personally.I would be happy to answer all your queries.
Now regarding to your concern, from now onward ,Yes this tool is part of NI software.
It might have possible the tags which i have used is not working, But it was generalize question regarding to ASCII to INT conversion.
Now regarding to your example, if i buy the product from toyota which consist the few parts of ford, Then definitely, i would ask to toyota not the Ford.
Thank you so much for your precious time.
Best regards
Message 23 of 26
(1,272 Views)
Best regards
You really need to concentrate on doing your job instead of fixating on me !
And, yes, TSXperts is a completely different company than NI. They are a NI Alliance Member but not National Insturments and the compiler is not NI software. Your ignorance is showing!
Message 24 of 26
(1,258 Views)
Suyash,
It is probably a cultural thing.  But calling someone "dear" in a professional forum is oddly unnatural.  His comment may have been a bit harsh, but I wouldn't call it childish.
Message 25 of 26
(1,253 Views)
Hello
I know, there are different opinion regarding the salutation, But usually "Dear" , People uses to initiate the correspondence, with person to whom we never met.
I follow the same practice, but on this forum, if there are some other rules, then i will go trough it.
But if you feel that calling someone child who is pointing without knowing the background, is not justified, then i am taking my words back.
Message 26 of 26
(1,250 Views)
