ASCii code convert to decimal number
Hi, Steven
Thank you for your advice.
Root cause is the baud rate wrong selection.
best regards.
Message 11 of 17
(1,159 Views)
Hi, Steven,
I found that i selected wrong baud rate . Correct baud rate is 115200.
I managed to read the ASCII input data.
I found new problem.
My program can read incoming data (data from R-Visa) but just starting period only.
Do you know why ?
Attached images files for your reference.
Message 12 of 17
(1,137 Views)
Hi, Steven,
The data is from Bluetooth receiver.
Data format is ASCII.
best regards.
Message 13 of 17
(1,142 Views)
Accepted by topic author Jeffrey_Oon
Hi Jeffrey,
Do you know why ?
Still no VI, just images: how should we edit/debug them with LabVIEW?
Replace the BytesAtPort by a numeric constant, and set its value to 999.
Also remove the "Wait before read" sequence frame completely with its content!
Message 14 of 17
(1,141 Views)
Hi, Gerd,
Sorry, attached my project file for your study.
Thank you very much.
Message 15 of 17
(1,136 Views)
GerdW already gave you good advice:
Here's a cleaned up version that should work.
Message 16 of 17
(1,129 Views)
Hi Steven,
More improvements:
  • No need to set the file position to "end" in each iteration. No need to set that at all…
  • I would replace the Num2String/FormatTimeDateString/BuildArray/ArrayToSpreadsheetString with just one FormatIntoString (in this simple case)…
Message 17 of 17
(1,123 Views)
