AT Commands using TCP/IP Connection with GPRS Modem
Hello, I'm trying to communicate with a GPRS Modem by using AT Commands, I tried this manually by sending commands through Telnet and Hercules Software so modem is responding correctly.
I want to do the same using a Labview VI, so when I'm runnning the VI it seems that commands are send correctly but I dont get any answer from the modem. I  don´t know if I'm using \n\r characters ok.
I would appreciate any help
(5,376 Views)
Accepted by topic author lenin_7
When you press the enter key in a terminal program it sends normally the carriage return and line feed character. You have to do the same in your LabVIEW strings by adding those characters to the end of a command string.
Enable backslash code in the right click menu of your string control or constant and add \r\n to the end of your command string.
Rolf Kalbermatter  My Blog
(5,350 Views)
Rolfk Thank you very much for your answer, I attached \r \n commands to string and it finally worked.
I update VI for further information.
I'm using modem GP2 V2  from Witech.
(5,298 Views)
