Hello, I tried to use IMAQ AVI2 read frame to show the video,
However, the screen is always stuck during the process,
in the first, I thought that maybe the reason is about the 2G AVI file bug in LabVIEW,
although I compress it to a file smaller than 2G , the error still happen......
My LabVIEW version is 2014 SP1 (64bit)
Not all toolkits are 64-bit "friendly". I've only used 32-bit LabVIEW on 64-bit Windows (7 and 10). I have no problems with opening and playing AVIs. Do you have (or can you create) a small AVI that fails? If so, attach it and your code (as a VI, please) and I'll try it ...
Bob Schor
