AWG
Hi ! I want to generate a signal from which its frequency varies automatically in the frequency band. is there any equipment that allows it?
(6,428 Views)
Hi Akram,
Sure! Use LabVIEW…
Have you tried some functions from signal generation palette?
(6,426 Views)
Thank you answer, but what I mean is the equipment and not the simulation because I want to achieve a circuit allows the described operation.
(6,422 Views)
Hi Akram,
Then why do you ask in a software forum?
You should ask in a hardware-related forum!
Suggestion:
- Use some timer ICs like the famous 555. Have one 555 generate a voltage ramp and use voltage to drive the frequency of another 555…
- Buy some real AWG devices…
(6,417 Views)
sorry,and thanks a lot.
(6,410 Views)
Yes, they are often called Function Generators, Arbitrary Waveform Generators, or Sweep Generators.
Every major test equipment manufacturer makes one. The sky's the limit on price and options, although I am guessing you would want one that has a remote interface be it USB or whatever and some prefab LabVIEW vi's to control it so I would recommend a major brand like Keysite, Tektronics, LeCroy, or Fluke.
BTW: You did not mention a frequency range...
=== Engineer Ambiguously ===
(6,373 Views)
A solution ?
(Use the PC Speaker/Soundcard)
Greetings from Germany
Henrik
LV since v3.1
(6,348 Views)
