Abort Execution leaves USB port open
My VI opens a USB port and then processes the data in a while loop for as long as I let it run.  When I manually exit the while loop the VI closes the USB port and then stops execution.  Using the start control starts the loop again and the VI runs.  However if I use the abort execution button on the toolbar the VI stops without closing the USB port and the VI will not run again unless I  close and reopen it.  How do I avoid this problem?
(3,133 Views)
Accepted by topic author JohnP
So I suggest always stop the program from the front panel button.
You can hide the toolbar so that the the abort button can not be clicked.
Best Regards
Hu Yu
(3,132 Views)
