Aborting a copy function
Is it possible to cancel copying a large file while it's in the process of transferring? I am using the standard 'Copy' function.
(1,750 Views)
Accepted by topic author slintak
You could do something like this: File transfer with progress bar
This breaks the file into chunks and transfers it in a loop, so if you need to abort it for some reason you can stop the loop.
(1,745 Views)
Thank you, that example is very helpful.
(1,679 Views)
