The file Dialog has 3 outputs : one is the file path, the others are booleans values indicationg the operation has been cancelled, and that the selected file already exists.
Simply put the file saving operations in a case structure, and wire the case input to the "Cancelled" output.
Managing the "File exists" is more annoying : You will have to dig one level below the Write characters to File.vi, or whatever high level file save you are using, to
change the value of the "Advisory dialog?" constant input of the Open/Create/Replace File.vi, to avoid an annoying dia
Chilly Charly (aka CC)
