AbouT using Labview through Activex to control USB Camera
Hello All,
I have LV7.1, IMAQ6.0 . I can't use the IMAQ for USB Camera,
Someone suggest me try to use activex to control webcam.
Is activex can control the usb web camera?
How Can I use the activex to control the Camera?
Would someone send a simple example for me to observe??
Thank you!!
(3,332 Views)
Try this (LabVIEW Webcam Library) or consider following this [broken link removed; article no longer available] guideline from NI.
Hope this helps, Guenter
(3,317 Views)
I've try the LabView Library before, but I find out that the frame rate very slow about 2 frame/second.
and it's respond time are quite slow.
Thank you
(3,302 Views)
