About PCI-6534 and analog acquisition
I would like to program an application in which the main signal comes from an incremental encoder, so I need to perform pattern I/O digital acquisition. I´ve been recomended to use one of these boards: PCI-DIO-32HS and PCI-6534. These boards only have digital channels but I may have other signals, maybe analog ones. So, is there any other board that I can use and that let me acquire an analog input too?
Thank you very much,
Inma
(2,674 Views)
Hi Inma,
Sounds like you want a multifunction board.
You could always check out NI's website, ni.com. They definitely have the
boards to which you're referring. Another nice alternative:
Measurement Computing
http://www.measurementcomputing.com/
PCI-DAS6025
PCI-bus compatible, 16 channels of 12-bit A/D board with two
12-bit analog outputs, 32 digital I/O lines, two 16- bit counters
$495.00
OR if you don't need that much I/O or a programmable gain, check out the
DAS08 for half the price.
PCI-DAS08
Low Cost, PCI-bus Compatible, 8-Channel Analog Input Board with 7 Digital
I/O Bits and Three 16-bit Counters $249.00
Another great company is United Electronic Industries, www.ueidaq.com. I
haven't tried their boards yet but I hear they're of exc
ellent quality.
They have an enormous cPCI selection with prices better or equal to NI.
- Kevin
In article <50650000000800000055610000-1031838699000@exchange.ni.com>,
> that I can use and that let me acquire an analog input too? Thank you
> very much,
> Inma
(2,674 Views)
