About calling dll
Message 1 of 15
(6,274 Views)
It's not a TCHAR. TCHAR is the Win32 API name for a character code point that could be either Unicode or ASCII depending on preprocessor magic. Because your API specifically specifies that it is Unicode and Visual Basic Strings are Unicode anyways by default it is an array of WCHAR's.
This is basically an array of uInt16 integers. And you will need in addition to use some ASCII to Unicode conversion library to convert your LabVIEW strings to Unicode strings in order to pass them to this function.
The function name you need to set in the Call Library Node configuration is most likely called lmcl_initial2 and not Initialize, which is only a Visual Basic alias to use in the Basic program.
Rolf Kalbermatter  My Blog
Message 2 of 15
(6,217 Views)
23.JPG23.JPGWhat I mean is how to define the parameters of the library function"strEzCadPath"type
thanks a lot !
Message 3 of 15
(6,200 Views)
Array of 16 bit integers passed as C string pointer.
Message 4 of 15
(6,161 Views)
I am sorry! I still did not understand, you can not say the details of the point.
such as:
Types of:?
constant:?
type of data:?
Data Format:?
thank you very much!
Message 5 of 15
(6,148 Views)
rolfk 已写:
such as:
Types of:?
constant:?
type of data:?
Data Format:?
Message 6 of 15
(6,147 Views)
@NJ_yang wrote:
rolfk 已写:
such as:
Types of:?
constant:?
type of data:?
Data Format:?
Name: irrelevant for the functionality, only for documentation
Type: Array
Constant: checked if it is an input parameter to the DLL function, not checked if the DLL writes something into it for the caller to use, but if you leave this unchecked it is always safe just may prevent LabVIEW to do some extra optimizations
Data Type: (signed or unsigned) 16 bit integer
Dimensions: 1
Array format: Array Data Pointer
Minimum size: <None> if it is an input parameter to the function, otherwise the number of elements the array should provide for the function to write into, according to the documentation for the parameter for this function.
Message 7 of 15
(6,120 Views)
Dear rolfk, thanks for your help to let me have a new direction.
I would also like to ask how 16-bit integer array can include (TCHAR * strEzCadPath, BOOLbTestMode, HWND hOwenWnd) type, is not to convert the input parameters into 16-bit integer array?
thanks a lot
Message 8 of 15
(6,098 Views)
It doesn't include all those parameters, only the first!!
And you need to convert LabVIEW strings into Unicode strings in order to pass it to this parameter. LabVIEW strings are 8 bit Multibyte Code Sequences (ASCII for most western locales).
There are routines to do that, namely here! you can also download this with VIPM under the name ni_lib_unicode-2.0.0.4.vip or maybe a newer version.
Message 9 of 15
(6,084 Views)
Accepted by topic author NJ_yang
The other parameters are:
Type: Numeric
Constant: checked
Data Type: (signed or unsigned) 32 bit integer
Pass: Value
Type: Numeric
Constant: checked
Data Type: (signed or unsigned) pointer sized integer
Pass: Value
Message 10 of 15
(6,081 Views)
