About communication between C program and VI with CIN
I programmed a VI includes an UART communication CIN to communicate with a C program end. Now this two ends cannot communicate in same speed (bit/sec). If the VI is given a higher speed than the C end it can receive a correct data from the C end but has a Framing error. The C code in CIN can communicate with C program end normally. Does VI affect the UART communication setting? Analyzing the hpenomenon, the VI will slow down the CIN communication.
I will be very glad that you can give me any advice.
Thanks in advance,
James2001
(2,637 Views)
Probably it's true that the VI slow down the CIN (the time required for exchanging data). In order to avoid different processing speed, try to implement handshaking.
(2,637 Views)
