About error -1074396077 (IMAQ Vision: Incompatible image type)
Hello, I am trying to program pattern matching and this error -1074396077 (IMAQ Vision: Incompatible image type) occurred at IMAQ extract.
However, this error doesn't occur when I run the program step by step with highlight execution. I don't know why this error occur only when I run the program normally.
Please tell me how to fix this.
I attached VI files(main and sub). This error occurred in subVI at the point I marked in a bellow picture.I use LabVIEW 2016.
Finally, I'm sorry that I'm not good at English. I'm Japanese...
Thank you for reading to the end.
(7,482 Views)
I found more information about my program.
If I don't use "case structure" around "eye direction_subVI.vi" the error still occur.
However, if I don't use the "case structure" and directly program(not using subVI), the error doesn't occur.
I don't know its meaning. Can anyone tell me what happen?
(7,441 Views)
Accepted by topic author nicole12
I solved myself !
Thank you for reading and thinking my problem.
(7,422 Views)
Thanks for accepting a solution.
Would you mind sharing the solution? That might help others in the future.
(7,415 Views)
Sorry, I write the solution.
When I programmed, I referred to this  "https://forums.ni.com/t5/LabVIEW/IMAQ-extract-1074396077-Crop-Image/td-p/3142082".
I solved my problem with the save, close and reload.
(7,398 Views)
The image type solved my issue as well along with using Convert an IMAQ Image.
Thank you.
(7,293 Views)
