About the article "Timing and Synchronization Features of NI-DAQmx"
While using the smple "Synchronized Analog Input/Output",I could see the input measurement at the front panel.And now I would like to see the output measurement at the front panel .Trying to plus the measurement to output channel at the block diagram didn't work at all.
How to let the output measurement work?(In block diagram)
Thanks for help.
(1,342 Views)
What is an "output measurement"?
What do you mean by "plus the measurement".
Why don't you attach your actual VI so we can see what you are doing and make suggestions.
(1,330 Views)
This is the vi,the sin wave shown on the monitor is the input. In this case,I can't see the wave of the output.
I wanted to set another monitor of the output,so I called that output measurement.
So how to set another monitor?
Thanks.
(1,306 Views)
Please read RavensFan's note carefully.  Then attach your VI !!!  A picture of its Front Panel doesn't tell us much about the code.
As you are new to the Forums, you might not realize that we are not very good at "guessing" what you don't know, or did wrong, or don't understand.
My "guess" would be that you have not taken enough of the LabVIEW Tutorial suggestions on the first page of this Forum to have learned how to do Charts, in particular how to plot two signals on the same Chart.  But that's just a guess.  Please attach your VI and save us from more guessing.
Bob Schor
(1,283 Views)
